주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Boot loop caused by broken proximity thing?
Hello
I recently replaced my iPhone 6 screen.
During replacement, I broke my proximity meter thing.
The phone powered up fine, everything was working except for the proximity thing (when I made calls and held the phone up to my face, the screen didn’t turn off like it usually did).
The battery eventually died, and when I tried turning the phone back on, it got stuck in a boot loop. The apple logo seemed to flicker in brightness and sometimes I would get a red screen flash.
Other posts on here suggest disconnecting the cable and then trying to boot the phone up.
I did that, but the phone is still stuck in a boot loop with a red screen flashing sometimes. I also tried disconnecting everything but the home button and the screen itself. Still no luck.
Will installing a new proximity meter flex thing fix my phone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Replace the proximity sensor cable. Then do a full restore via iTunes. It’s a hardware issue that caused a software glitch. Also try using the lcd shield from your old screen if you’re not already as aftermarket ones cause problems.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brink Laubscher 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 66
