주요 콘텐츠로 건너뛰기
Created in 2013, the Acer Aspire M5-583P-9688 is a slim model, Windows software based laptop constructed by Acer.
3 질문 전체 보기
How do you replace the screen?
What is the procedure and what do I need to replace the screen on this
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Touchscreen or the LCD?
With this model you should be able to pry around the displays plastic bezel and the back LCD cover.
this will allow you to get the front screen off. If you need the touch then find another one of those. There should be model numbers somewhere on it to find.
if the LCD then remove the supporting screws and then pull it up slowly. Disconnect the cable from the bottom of the LCD and then find the LCD. Should have part numbers/model numbers to look it up.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jake Mancini 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 314
