주요 콘텐츠로 건너뛰기
Samsung의 주력 휴대폰 Galaxy S8. 2017년 4월 출시.
304 질문 전체 보기
Is it possible to extract the internal memory of the phone and read it
Hi, I was wondering if it is possible to take out the memory of my galaxy s8 and read that information somehow. My phone was water damaged and I think the insurance will replace it so I want to have all my pictures and other information with me.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Have you looked into the water damage? There are basic steps you can do to see without opening the device. I have had some people who had water damage devices but when inspecting water barely goes into the device, which is something I find interesting with the newer samsungs.
Basic Inspection.
  • Sim Tray- pop it open and remove the tray, look around for a White or Red marker (its a sticker inside the phone.) if you see Red, then water went inside the phone. If it’s white or white with purple marks, most likely minimal to no water went inside the phone.
  • Inspect the charging port - this one may be a bit more difficult if you don’t have a magnifying glass or sharp eyes. Get a light and inspect for Greenish debris/residue. If you see this, you can simply clean it with 99% alcohol, tooth brush, cloth, and a hair dryer on standby. Apple to the brush but not to the point where it’s dripping. just a small amount. Hold the device upright and brush it (literally like brushing teeth). Pat it dry and apply some heat to dry the alcohol. Inspect and see if the residue is not gone and the gold contacts are visible and clean. After drying the alcohol let it sit for 5-10 mins. Do a test charge and see if it will charge.
This should at least help connect to the computer, then you can use samsung smart switch application to transfer everything to the computer.
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your answer, very helpful
댓글 달기
Unfortunately from my experience there is not. You can take it to a data recovery specialist and they will have tools to extract the data but this will be quite expensive and is not guaranteed to work. I’d suggest next time to back up the phone regularly or use apps like Google Photos to store images only.
If you saved data to the SD card, you can remove this and put it in your new phone (it will probably be fine after water damage)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
Michel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 22
전체 시간: 916
