주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
iPhone suddenly dim on upper left corner
Hello. My iphone is suddenly very dim (vignette) on the upper left corner. If I go 50% brightness, the upper left portion is stuck at around 15%. Just brought it 1 month ago from a friend, no issues until now.
I didn’t drop it or no water damage. It was fine when I put it on the bag and then when I try to use it again, the problem is already there. Sometimes when It will go back to normal when I put the brightness at 25 below.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Usually this is caused when the screen has been replaced (probably your friend had it done before) and the screen cables are not fully connected.
There are other rare causes where it is caused by the screen having a faulty backlight instead which would require getting the screen replaced to fix the problem.
Replugging the screen cables most of the time will fix this problem. If you are planning to reseat the screen connectors you must make sure to disconnect the battery first because the backlight circuit is very easy to blow up on the 6s models.
Follow up to step 19 of this guide which is where you unplug the screen display ribbon cable from the screen, the other cables do not need to be unplugged:
iPhone 6s Plus Screen Replacement
Otherwise it’s a bigger issue with the screen connector on the board or the backlight circuit which either require taking the phone to a reputable shop that does board-level repairs / microsoldering to get it fixed.
TL-DR: First take it to a reputable phone repair shop to get them to try fix the problem via reseating screen cables first, then a screen replacement, last resort board level repair.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks for this. Btw to clarify, when I turn it off then on, it will go to normal if the screen brightness is around 25%. Then the dim corner will pop up if I go change the brightness.
댓글 달기
귀하의 답변을 추가하세요
Joshua Pamintuan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 2,305
