Low beams and daytime running lamps not working
2005 chevy express van low beams and drl’s not working. Hi beams and all other lights working fine. Problem started as intermittant but is now totally out. No power coming from any of the 4 fuses that control these. I have removed, taken apart, cleaned the fuse box under hood to no avail.
Update (09/09/2018)
I have also swapped relays to no avail
좋은 질문 입니까?
점수
0
@fitzetra do you have power to the relays?
oldturkey03 의
Yes i have power to the low beam relay bottom right pin on fuse box
fitzman12 의
Actually power to top and bottom right same as hi beam relay which is working. Tested with relays pulled out
fitzman12 의
