What happens if I replace the motherboard?
My sister’s tablet has bad charging port so it can’t charge or turn on. I’d like to replace it but, it’s connected to the motherboard. I don’t know if she’ll lose her apps or pictures.
좋은 질문 입니까?
좋은 질문 입니까?
After digging around some more I came to the conclusion that if you replace the motherboard the storage is attached to it so you will not be able to keep your files. Unfortunately your sister will lose her pictures and apps if you replace it. Sorry to be the messenger of bad news.
해당 답변은 도움이 되었습니까?
Actually, if you have the micro SD card system, you could simply transfer or copy your files and most app data(or probably all of it, but I’m not sure about photos ,you could probably use google photos for that) into it and simply remove the card and just re-install it after replacing the motherboard(after making sure its compatible with your tablet after replacing it’s motherboard)
해당 답변은 도움이 되었습니까?
And then you just need to copy all the data back onto your device storage, I hope this helps other users of different devices too :)
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 459
