주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Battery condition: replace now cycle count 258
Just bought a Early 2015 MacBook Pro with a faulty battery, it only works with charger plugged in, but when looking at the cycle count it’s seems pretty low for a full replacement (258) Is there any way to reset the warning before I do the battery replacement which doesn’t look fun with the amount of glue they use on holding these in. Any help will be much appreciated I’ve tried a SMC reset but no luck
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 4개
Hi,
i thought before i bite the bullet and send it to my logic board repair guy I’d fit a new battery just to make sure, just arrived and fitted it laptop is now fully working again without the charger and when plugged in is charging at 22.1 watts turned out it was a faulty battery.
Does the new battery come with a chip to count new battery cycles ?
Yes, all good quality batteries have that.
The cycle count doesn't tell you how long the batteries were fully charged (laptop permanently plugged in). My 13" MBP Early 2015 had a low cycle count but the batteries were severely distended due to outgassing, resulting in a wobbly laptop and a bulged keyboard.
The battery removal process is tedious but feasible with an hairdryer and a PVC card (e.g. an old bank card or old credit card). Once you reach the battery connector, please tape it once disconnected to avoid accidental ESD damage.
댓글 달기
답변 1개
가장 유용한 답변
You could try resetting the SMC but that won’t really solve the issue if the battery is gone.
How about getting a bit more diagnostics here to see where the problem is as it could be something more than the battery. Run this app CoconutBattery and paste a snapshot of the main window so we can see what it its telling us 기존 질문에 이미지 추가하기
Update (09/10/2018)
Sorry to say the charging logic has a failure if you look at the snapshot you’ll see the two clues the first is the charger is connected and the second is the ‘Charging with’ 0 Watts with your battery exhausted ‘Full Charge Capacity’ The logic is split across the DC-In board the sense part and the main logic board which has the switching MOSFET’s that sends the power to the battery. Basically, your logic board will need repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hi, thanks for the reply.
Ive added a pic to the original question
댓글 달기
귀하의 답변을 추가하세요
Robert Culton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,703
