주요 콘텐츠로 건너뛰기
2014년 9월 9일에 발표된 이 기기는 Apple의 첫 번째 스마트 웨어러블 출시제품입니다. iFixit의 수리 설명서는 Apple 워치 (스틸) 및 Apple 워치 Sport (알루미늄)에 적용됩니다.
Apple Watch Stuck on Logo after Screen and 3D Touch replacement
After successfully replacing a friends Apple Watch screen, I noticed the 3D Touch sensor was broken, and the watch would not turn on past the Apple logo. I ordered a new 3D Touch sensor + adhesive from the site as well, and just installed that, thinking that was the issue. Now I have installed the sensor and the screen all back on (and battery), and the screen is still stuck in the Apple logo. Does anyone have any ideas what might be going on here?! The watch will turn on to the Apple logo, screen appearing to work fine, but it’s stuck there. Before applying the outer adhesive/gasket I want to figure this out. Any ideas? The watch turned on and worked fine prior to changing the screen, it was just terribly cracked. Before doing any of this I tested it and it appeared to work fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
Where did you get the replacement screen? Did you order the correct one for your watch?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I got it from iFixit as well. And yeah it’s the 38mm original Apple Watch.
댓글 달기
There seems to be a software issue that affects the original series watch.
I have the same problem. Wont pair, intermittent apple logo that occasionally fades into red & also a red exclamation logo screen.
Never resets or boots. Cannot be detected by iphone to pair.
An Apple Genius tech in London simply rejected any repair as original watch is basically classified as obsolete.
Possibly if us civilians had the right hardware to access the hidden port & the files to debug the OS software/ firmware it would be a fix; but I see nothing on line to suggest anyone has got that far…
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi
Did you remove the battery as iv seen apple watches that have half of the battery connector torn which results in this
Hopefully this helps
@matthewkiernan - Nope that's not a software issue its a failing battery!
댓글 달기
답변을 추가하세요
Chris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 544
