주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
Dim lcd after water damage. Inverter or LCD?
My macbook was damaged by some water drops that went in. The screen is working normally and I can see everything when I shine external light on it. I was told by a repair shop (not apple certified) that I need to replace the whole LCD for almost 500$. I want to make sure if it’s an LCD cable problem or just inverter. Please note that the screen is absolutely fine and is just dim.
thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I doubt you need a new screen. This model does not have an inverter, but a LED driver for the backlight LED’s, in addition there is a fuse link that could be blown. But before we go down that path lets do a better job diagnosing things.
Lets take the bottom cover off so we can see the display connector compare it to these two images of the cable and board. If they are grey or have any corrosion you’ll need to clean it off and hopefully that was the cause.
If you see any other signs of damage take a few pictures and post them here for us to see 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ghadeer Omer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 127
