pelonis stand up fan wont turn on anymore
hello all of the sudden my pelonis stand up fan just stop working help
좋은 질문 입니까?
좋은 질문 입니까?
Power Problems
Power can be disrupted by problems in the plug, cord or switch. Examine each piece for any breakage or damage. Use an ohm meter to verify that power is moving through. Replace these pieces if they’re responsible for the power lack. However, if the plug, cord and switch are working, your problem is your motor.
Motor
Foreign objects entering your motor may cause the mechanisms to stall. Open the grill and examine the central motor for any damage. Hairs and small objects can be pulled into the motor, damaging normal usability. Clearing the motor of obstructions may help return your floor fan to its normal power.
If cleaning your motor doesn’t help, look at the fan belt. If the belt is damaged, contact the manufacturer for a replacement. If you still can’t make your floor fan work, replace the motor.
해당 답변은 도움이 되었습니까?
It’s a brand new fan. The blades won’t turn around.
Kathy, just return it for another one. It's under store warranty and then under manufacture warranty. Not worth your time to try to fix, nor should you on a new machine.
24 시간 전: 9
7일 전: 36
30일 전: 119
전체 시간: 10,394
댓글 3개
Hi @ngaytan
What had you checked?
ensure there is power
when you open up and try spinning on the fan blade, any resistance?
Augustine 의
fan all of the sudden stopped working checked motor and still clean only had fan 4 months, what should i do,
Shannon Romero 의
If it is new, contact manufacturer for a repair / replacement. I believe there should be some warranty on this.
Augustine 의
