주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
274 질문 전체 보기
Newest Logic Board Upgrade for my MacBook?
I have an issue with my early 2013 15” and the logic board needs to be replaced. What’s the newest board I can get between 2013-2015 models? I don’t want to have to end up replacing every other part as well. But i’d much rather buy a newer Logic board than pay Apple to replace my current one. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
You will only be able to put a logic board from another MacBook Pro with the same series identifier (in your case MacBookPro10,1), which means you will not be able to put any newer in series wise. You will however be able to put a higher spec logic board within the series, for instance if you have the 2.4 GHz i7 you can place the 2.7 GHz i7 board in for an upgrade, or if you have 8 GB of RAM you could put in a board with 16 GB of RAM (note: it will cost more though). Just make sure it is the SAME identifier as your current MacBook Pro.
I would suggest you by the board from ifixit:
MacBook Pro 15" Retina (Early 2013) 2.4 GHz Logic Board
OR
MacBook Pro 15" Retina (Early 2013) 2.7 GHz Logic Board
Either of these should work. (Going off the info you gave me, double check to be sure.)
But if you want to save a buck, you can search eBay as well, but watch for scams.
MacBook Pro 15" Retina (Early 2013) 2.4 GHz Logic Board 이미지
상품
$159.99
MacBook Pro 15" Retina (Early 2013) 2.7 GHz Logic Board 이미지
상품
$199.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Miles Somerville 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 306
