주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2133 질문 전체 보기
How do I fix a bent USB port
My case has 2 ports on top like most cases and I accidentilly put in my mouse the wrong way around. It managed to push the plastic bit of the usb port a bit forward. My question is if I can bend it back if so do I have to. The port is still functioning fine but I dont want to run any risk of a short circuit.
The case I’m using is a mastercase pro 6
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Joey
Well, I would say it depends.
shutdown and off the computer mains before doing anything.
Of course to reshape and bend it back, you need to assess and check how bad is it. Of course sharing couple of pictures is great.
same for some of my users…….accidentally tugged on the wires and usb socket got damaged.
so on this… you have some options…
  1. if you are able to get the usb socket, you can take out the I/O board on the casing and with some soldering skills, remove and replace it.
  2. Order the replacement usb i/o board from coolermaster or service center / distributor.
  3. check with distributor if they are kind to change for you.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Joey Li 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 2,303
