주요 콘텐츠로 건너뛰기
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 질문 전체 보기
PSP go wont turn on when charger plugged in
The PSP turns on and works fine but whenever I plug in the usb charger, the system turns off. The usb side doesnt even have to be plugged into anything, once I jack it into the PSP it will turn off. I set it to USB mode but thing works. The battery still charges though.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Are you talking about a cable? If the other end is not plugged into a USB port and the thing is shutting off, that would suggest the cable you are using may be bad - as in shorted. I would try another cable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Okay thank you I bought three cables on amazon and apparently one of them worked. I assume yes it was causing the PSP to short.
댓글 달기
귀하의 답변을 추가하세요
Alejandro Tellez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 314
