주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
When I turn 3DS on, blue light appears but screen is black (has CFW)
So I was playing ACNL, then I put my 3DS in sleep mode after I was done playing. A week later, I come back to play and the screen is all black, though the blue light is still there. I figured it must have somehow froze, so I held the power button to turn it off entirely. Unfortunately, after that, every time I tried to turn the system on, the blue light appears, but the screens remain black, and I can’t actually do anything on the system. I‘m not sure what to do. If it matters at all, it does have CFW installed, but I doubt that’s the issue, as it’s been installed for about a couple years by now with no problems.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 18
댓글 7개
Anyone have any ideas on what could possibly be wrong if I have tried to Wi-Fi fix and it doesn't make screen turn on? I'm at a loss. This originally stopped working 13 months after purchase and Nintendo wouldn't fix because it was after 1 year warranty window. And I was angry so was boycotting paying the $150 fee to have fixed. Now I wish I would've done that because they do not even repair these any more
NINTENDO 3DS XL "galaxy"
Do I need a new battery? I did everything I could and updated it and got all the new files and deleted the old bad ones and everything. it’ll turn on for a little, but it always goes right back to it. It’s weird cuz you can see the screen turn slightly brighter like it’s on, but it’s not I don’t know. Any advice please anybody???
does anyone to fix it without opening the ds\
I have the same issue like some times it will work without a problem but the next day it's just a black screen, but the blue power light is still on, how fix please someone help. At this point, i want to` buy a new 3ds
@icebluelugia yet again, could be bricked, have you tried updating any software left or do safe mode? lmk
댓글 2개 더보기
댓글 달기
답변 10개
가장 유용한 답변
Hi!
You could try the following:
  1. Remove the battery
  2. Press the power button a couple of times
  3. Plug in the power adapter. Try turning it on.
  4. Remove the power adapter
  5. Insert the battery, plug the adapter in
  6. Try to power the console on again. If it works, you’re good, otherwise I’d try the same again also with removing the SD card.
이 답변이 도움이 되었나요?
점수 21
댓글 20개:
Sorry for the late reply. I actually had seen someone else suggest this as well so I wanted to try it, but unfortunately the screws are stripped so I can’t actually get to the little nudge in order to pull out the battery. But the back cover itself broke off since it was kind of cracked, so I’m able to access the SD Card, just not the battery. Is there any way I can remove the screw?
I just made an account to say thank you. I was going crazy and couldn't find how to fix it, thank you so much!!!
This worked! I was about to give up hope when the wifi-chip fix only worked once, but before my eyes it finally turned on. Thank you so much!
Pranav, if you still need a way to open up your 3ds (after 4 years) you can try using a rubber band between the screwdriver and the screw, and as a last result you can drill off the screw top.
Thank you! It worked!
댓글 15개 더보기
댓글 달기
This is a fairly well known bug with luma. Turn it on and leave it open and undisturbed for about 10 minutes. If it boots by then, you're good to go and probably won't have to worry about this again
이 답변이 도움이 되었나요?
점수 5
댓글 39개:
Do you have any advice for a 3ds that is having this problem without any CFW installed?
@standardtoad When did it start, and what were you doing with it just before?
Well, this happened some time ago and I basically gave up. I was playing some MH4U and doing the online mode when the 3ds crashed. It was able to reboot, but after I continued playing it crashed again and got stuck on the black screen of death. I then used the safe boot to try and check for updates, but I wasn't missing any and the 3ds still wouldn't boot normally, always going to the BSoD. I then checked online and tried methods like disconnecting and reconnecting whatever the thing on step 12 of the teardown highlighted in orange is. That worked for about 2-3 boots until it crashed again and got stuck on BSoD after playing some online Pokemon. Around this point, the safe boot no longer worked, since it would crash after about 2 seconds. The last thing I did which worked temporarily was the procedure mentioned in the top answer here, but it only worked for one boot and didn't work after that. As of now, the 3ds no longer boots even using safe mode and none of the methods that worked before succeed any more.
The teardown I mean is the Nintendo 3DS XL 2015 Motherboard Replacement. I have the New Nintendo 3DS XL, SNES model. Nintendo has already rejected my device for repairs, which I guess was because either the warranty expired or because I bought it from Amazon instead of directly from them.
@darthmango I don't know if this is enough information to figure out what is wrong, but the main problem that seemed to happen was that even though the 3ds was updated and had internet connection, the crashes all seemed to happen when playing games and using the online features.
댓글 34개 더보기
댓글 달기
Download the latest version of Luma3DS and copy the boot.firm file in the archive to the root of your SD card, overwriting any boot.firm file that might already be there.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
The link to the latest release of Luma3DS is always available on GitHub at https://github.com/LumaTeam/Luma3DS/rele...
Also try a different SD card. If none of this works, try holding (L) + (R) + (A) + (D-Pad Up) all at the same time, then while still holding them, turn it on. This should bring up a System Settings menu to update the system. As long as you put the latest boot.firm on your console beforehand, updating from this extra menu (called Safe Mode) should be safe to do. Updates using B9S+Luma are safe, as long as you update Luma too. (if you don't update Luma, you'll run into the same issue you're already having until you put the new boot.firm on the SD card.)
This worked for me when I updated Luma3DS.
After doing my research, my son updated the 3DS system. So I had this problem.
댓글 달기
So I litteraly removed the sd card, turned it on and it worked then put the SD card back in after turning it off. Works fine again.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This worked for me too, just turned off my console removed and inserted the sd card and then it turned on
댓글 달기
Okay so I had this EXACT problem with my 2ds (instead of a regular SD card, I had a 64gb micro SD inserted into a regular SD card adapter) turns out it was the adapter that wasn't working (not the micro sd) as once I replaced it with another adapter I had lying around it booted up per usual and I've had no problems since!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi I need help as well my 3ds is doing the same thing I updated it and got rid of the old files I replaced and did everything. I even took out the sd card and back and it would sometimes work for a little, but then would just start doing it again. It’s weird cuz the screen gets slightly brighter like it’s on when it’s not. I think I might need a new battery, but i don’t wanna buy one if that’s not the case yk.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The way I got it working was I removed SD card turned it on and got a crash dump thing turned it off and then popped it back in and I powered on and held select to bring up luma and after that it booted up with all my stuff intact
No wonder some guy said that luma will prevent your 3ds from becoming bricked
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
is it still able to boot with no SD inserted?
댓글 달기
I'm having a black screen issue with my 3DS after the Luma config v13.1.2 screen. After I save and exit, the screen goes black again. Removing and replacing the battery temporarily fixes it, but the problem returns. Also, I can't access recovery mode despite trying the right button combination. Any advice?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
when i do the r l up on d pad and a button it wont load into the safe mode screen please help me!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the answer
First you shut off your 3DS by pressing and holding the power button then you remove the SD card or microSD card, then you boot it on and it should boot up back normally. Then you can re-insert the microSD card while the 3DS is still on.
easy fix
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pranav Iyer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 82
지난 7일: 592
지난 30일: 3,278
전체 시간: 140,193
