주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
My S5 will not reboot.
Hey guys need some help. 3 yr old Galaxy S5. When trying to turn on, It repetitively keeps trying to boot does not even make it past the main screen. I believe my motherboard is shot. The battery is fine. Does get very warm when trying to reboot. Seeing how I can’t turn phone on to transfer my contacts. Can anyone get my contacts out of it. I am not willing to pay the price of another phone to do so though. That is plain crazy talk. They want a $40.00 bench fee to even touch it. then $90.00/hr to fix it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
I could be wrong, been a while, but if trying to transfer contacts to another phone, it will save through the GMAIL on the phone as long as it was synced with everything. Which would of auto done so if you didn’t do anything with it.
When it comes to fixing it, if you haven’t tested the battery, try getting another one, or a step that may see if its the problem. Take the battery out if possible on that phone, in which I think it is, plug the charger in, and see if it turns on being powered directly just from the charger. Turns on then buy a new battery. If the motherboard is killed, you can't do anything besides replacing it and I’m not sure on replacing a phone motherboard.
But there is this!
Samsung Galaxy S5 Motherboard Replacement
An IFIXIT guide on replacing the Galaxy S5 motherboard. The motherboard for the phone can cost about 20-30$ to buy online. Way cheaper than what you’re saying. So they’re is still a chance! Doesn’t seem very hard to do at all tbh.
ALSO! An easy test after the battery (If its not the problem) and to not spend money… you could try resetting the phone and see if that fixes the problem. I’m not sure if that would do anything but you could try.
https://support.bell.ca/Mobility/Smartph...
That guide is very very short and explains how you can reset the phone without turning it on. Goes into a form of safety bios mode in the phone. But you may want to keep your data on the phone in which this isn’t an option for you but if you are just trying to use it then you could try this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
HERACR 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 101
