주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone doesn't wake up from standby
Hey, my iPhone 6 doesn’t wake up when it’s on standby. If I press the home button or standby button the backlight is enabled but the screen stays black. I forced a hard reset by using dfu-mode and tried different batteries and displays, but it still stays the same.
Do you have any additional ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Does your display ever work, like when you boot it from a shutdown; or is it always showing the backlight but no image when it should be “on”?
Try connecting it to 3uTools (for Windows) when the display isn’t working to see if the phone is fully (or still) booted. If 3uTools sees the phone, then you probably have a LCD driver issue. This requires a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes when I boot it it shows me an image. Everything is fine then. I turn it into standby and after 5 minutes or so it won't wake up.
댓글 달기
Most likely it is a broken LCD. The backlight turning on with no image means that the connections between the cable and the LCD at the top of the screen under the front camera flex has been broken. This can be fixed by replacing the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried 4 displays. Problem stays.
댓글 달기
귀하의 답변을 추가하세요
elreparero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 245
