주요 콘텐츠로 건너뛰기
Stuck at looking for updates
Hi all I have a LG g3 vista love that phone its rooted one day it started acting goofy so I shut it off the next day I turn it on and its at the safe start or factory reset spot you can just continue they're also that's what I did didn't get anywhere so I tried safe mode didn't help so I did a factory reset bingo so I thought now it goes as far as to looking for software update that's it awesome phone would love to get it back..as a side note its not used as a cell phone its only for streaming to tv or I have a few things I stream to and I use it for internet so there ya go please let me know if you Think you might have the answer to fix Thanks…I don't have much if any access to a computer other then my tablet Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Thanks but no that's not it I've been using them booting or trying to boot it functions fine tell it gets to search for updates the twrp isn't visible and it should be
just says modified I thought it should have at spot in the safe start area that I can click on to get into TWRP but it's not showing
댓글 달기
답변 1개
check to make sure none of the buttons are stuck in place, volume, power etc. Could cause failed boot same way a lot of pcs or laptops won’t boot if you keep a key pressed down.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
im4ustgump 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 31
