주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6 Edge는 Samsung의 최신 주력 스마트폰 곡선형-스크린 버전입니다.
237 질문 전체 보기
Samsung s6 edge suddenly charging slowly
My samsung s6 edge suddenly not having a fast cbarging capability and will take 5-6 hrs to be fully charged without use because if you use it the batt percentage goes down instead of going up
I change almost everything adaptor whatsoever
Nothing works
And heres the deal
I tried to put alcohol on my broken chord and put it inside my s6 edge to try to fix the issue or clean it with it then it works its not fast charge atleast i got 1 hr 30 something to full charge but heres the deal it always came ack after a bit of time and i need to repeat and repeat that again for me to be able to charge faster need help thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
something nes like dirt on the pins inside the jack, if you have a compressed air can use it to blow out any dirt that might be inside the jack. If that doesn't work you might have to mod a charging cable with a bit of felt or similar soft material, moisten with rubbing alcohol and insert & remove it repeatedly to remove any drt from the pins.
As a side note, keep your pockets clean as that is usually how dirt would enter the jack in the first place.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Sometimes the charger port needs to be replaced to fix this problem, something a reputable repair shop can do via soldering.
Thank you i'll try it now
댓글 달기
귀하의 답변을 추가하세요
Fixie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 1,126
