주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Replaced Battery, % Now Inconsistent, Coconut Batt says "Failure- yes"
I replaced the swollen OEM battery in my MBP 2012 with one from ifixit. However, since doing so, the few times I’ve had to use it away from a power source, the battery percentage drops immediately from 100% to 94% and then falls quickly until the MBP goes into hibernation at around 40% - I might get slightly over 2 hours use out of it.
I’ve tried the SMC reset listed here: https://ifixit-eu-en.helpscoutdocs.com/a.... No joy.
I’ve installed and run Coconut Battery, which says “Battery Failure - Yes” amongst other things (I will try to attach the screenshot)
Is there anything I can do? Or do I have a dud battery and need to replace it again?
Thanks,
David
Update (09/21/2018)
Coconut battery screenshot:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You’ll need to get a replacement battery. There appears to be a problem with it. Look at your paperwork for the return instructions.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you - I will do that!
댓글 달기
귀하의 답변을 추가하세요
David Fardon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 176
