주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A point and shoot camera manufactured in 2014 by Sony.
How I can change a touch shot bottom
The touch bottom not work with the zoom and pictures eader?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I'm afraid your question is not very clear. Please could you describe in a little more detail exactly what doesn't work, and what still works. How did the fault appear? For example, did it do so suddenly appear or did it appear after a period of disuse?
If you don't find it easy to express yourself in English, that's not a problem. Try stating your problem in your own language and someone here can translate, or get a translation online.
The shutter button don't work to take a picture and zoon either, how I can fix?
thank you!
댓글 달기
답변 1개
선택된 해법
Following the repair guide referenced below, you may find the problem is simply a ribbon cable connector which needs to be reseated.
If not, search on eBay for another camera of the same make and model but with a different fault. You should be able to get one quite cheaply. Then learn how to disassemble it using the guides here and any other guides or videos you can find on the Internet. You should then be able to swap out the shutter and lens controls between your camera and the one from eBay. From a quick look at the guides it seems you may need to swap the entire front cover of the camera with the shutter and zoom controls attached, but that’s not a problem.
Having fixed your camera you can then try a more radical disassembly of the dead shutter and zoom controls to see whether they are fixable - it won’t matter if you break them further in the process. You might even be able to fix the camera from eBay and sell it for a small profit!
Sony Cyber-shot DSC-WX350
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Francisco maldonado 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 282
