주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
Power button not working
My power button is not working. Is there any solution to fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
was anything spilled on it?
댓글 달기
답변 1개
선택된 해법
I've yet to see a bad MacBook Pro power button that wasn't caused by moisture (water spill, etc). More often than not, there is oxidation on the power button switch that's causing the problem. Sometimes this can be cleaned off and made functional again but I prefer replacing the switch completely. The good news is the part is relatively easy to get and isn't that costly (about $10-$15). The bad news is to repair or replace the part requires pretty much a full disassembly of the computer. Not an operation for the faint of heart.
As a workaround, you can remove the lower case and disconnect your battery. With it disconnected, plug in the AC power adapter and the computer should turn on by itself.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Venkatesh Muthukrishnan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 1,570
