주요 콘텐츠로 건너뛰기
A general-purpose audio device that transmits low audio frequencies to your ears.
22 질문 전체 보기
What is this burned piece called
Punched my subwoofer cuz it wasnt working. I think it had blown voice coil. Semi worked then a few days later my stock amplifier from my 08 Mitsubishi lancer gts started smoking from under my seat. I took it out and opened it to find this. Can i take this piece out and fix it with a new one?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Brian .... that is the power amplifier IC
are you good in soldering, for this .... If you have a hot air…. desolder it, note the part no and order replacement.
some idea for you to read……
e.g. troubleshoot, inspect, etc.
http://jestineyong.com/two-ics-burnt-in-...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Brian Mcqueen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 7
전체 시간: 71
