주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
774 질문 전체 보기
Sound Distortion and cracking
My MacBook pro and the left speaker is distorted. I've tried resetting the NVRAM and SMC still nothing. I've Tried plugging in the headphones and its the same issue, its distorted on the left earphone. Tried changing frequency in the Midi Setup still and the issue still persists. The Startup sound is distorted also. At first i Had OS sierra installed when the issue occurred, I tried updating to High Sierra and still nothing. My current OS is Mojave.
Update (09/27/2018)
*Update* - now both speakers on the mac make the crackling sound like the volume is maxed out. However, on the headphones it’s only on the left side. I’m really out of ideas now.. Did a hardware check pressing “D” while booting up and it says that there is no issue. i’m at a total lost here
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Did you try a USB DAC adapter to see if it was a clean signal there?
댓글 달기
답변 2개
가장 유용한 답변
Did you have a liquid spill at one pointer sit the system down on a wet surface?
Why I ask is its very odd to have one channel have an issue if the DAC its self was having an issue.
I suspect the analog side of the connection has some corrosion which is shorting to ground enough to cause distortion issue.
You might also want to try a second system with the same data source or a USB DAC unit to see if the issue is the system or the recording.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, No liquid spilled at any time on my Laptop. where i live a MacBook pro is close to $20,000 so liquids don't go near it. Also I'm looking into getting some bluetooth speakers to see if i will get the same issue. The only thing i've tried so far is headphones, and speakers that connect through the headphone port.
댓글 달기
It might be a hardware issue too..if you hear music at a loud volume subwoofers sometimes crack, causing distortion. To be on the safe side before getting mad looking for deeper troubles or software issues I’d remove the loudspeaker and give it a thorough check with good light and some magnifying.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
the sound is cracking on the headphones too. So I'm not sure if its the speaker.
@jiographic You're right, if that's the case forget about the speaker.
댓글 달기
귀하의 답변을 추가하세요
jiovany 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 3,034
