주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
OWC with SSD via USB from old MAC not recognized on another MAC
My MAC died. Placed the SSD blade into a OWC Envoy Pro with a perfect match. When I plug it via USB into a working MAC it does not show up. If I use disk utility I see it as OWC Envoy media. However, I am unable to see the drive so that I can remove files.
Thanks
Marc
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 3개
What was the OS version you had on your Mac system and what is the OS version on your new system?
MAC OS sierra on both.
I have the same issue and I'm running Catalina . but can't read the SSD.
댓글 달기
답변 1개
선택된 해법
You may need to upgrade your MacOS to High Sierra on your new system if your dead system was running anything older. As your systems firmware needs an upgrade to recognize the newer file system APFS.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
What is going on when I plug a GUID external into a machine with APFS and it won't see it? P.S. I can migrate from it, but not see it otherwise.
Both HFS+ and APFS use GUID so I'm not sure I follow you here...
I think you're asking if a APFS drive can be accessed by a HFS+ based system. Well, yes & no ;-}
Apple claimed Sierra would recognize an external drive but I've not personally tested this. Anything older the answer is no.
Upgraded the OS to Mojave and that solved the problem. Thanks so much for the solution!
댓글 달기
답변을 추가하세요
Susan Turow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 46
전체 시간: 2,285
