주요 콘텐츠로 건너뛰기
2.3L 4cyl or 3.0L V6, 6th Generation
427 질문 전체 보기
Car wont start after putting gas.
My car was on empty so I put gas at a cheap gas station and i only put 3 gal and all of a sudden 30 min later it starting to shake and put and I pumped the gas paddle and try to idle it and it shut off on me. So I figured it needed a cleaning of then injectors so I walk to the auto place and bought Sea Foam and pour the hole thing in there. So it start and ran until I got to my house and it shut right off. Soni filled the gas tank up and it turned on again but then 15 min later it shuts off again so I turn the key and still wont start, it turns but dont stay on. So this morning it turned on like normal so I left it on and then once it got to the car temp of the engine I turned it off, and not it wont at art again. Any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
I have a similar problem. I have a 2002 Honda Accord and I was on E, went to the gas station put $10 in the tank and it wouldn't turn on and I had to have it towed home. I replaced the fuel pump and it started for like 3 seconds and turned back off. It will crank but not turn on. Did you figure it out in your car yet?
댓글 달기
답변 1개
Possible it is your fuel filter. I would change that out first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Noel Ortiz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 217
