주요 콘텐츠로 건너뛰기
A1708 / EMC 2978 — 2016년 10월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다. Function Keys 버전은 Intel Core i5 및 Thunderbolt 3 포트 2 개를 포함합니다.
216 질문 전체 보기
Screen continuous flashing problem
Hi all,
I’ve facing screen flashing problem last few week.
I’ve tried SMC & NVRAM reset. But not work for me. Screen still flickering/flashing.
I’ve also format my Macbook and install fresh copy of macOS High Sierra. Yesterday, I’ve update macOS Mojave. Still facing flickering/flashing problem.
Note: When I’ve moving the cursor “screen doesn’t flickering/flashing”.
Also If I’ve play any video(only) in any player or play youtube video “screen doesn’t flickering/flashing”.
If I’ve Minimize the player or bowser “screen flickering/flashing”.
**I’ve tried plug in the power cord & remove the plug of power cord, still facing the problem.
Check the video and Please advice me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
선택된 답변
It seems to me from the video you got a stagelights effect too on the bottom. That might be usually caused by the screen itself, screen connector, or by resistors along the backlight circuitry. You can try reseating the connector (turn off and disconnect battery connector first) and clean the cable end with a couple drops >90% alcohol. Other than that there’s not much one can do apart from testing the logic board and/or trying out a different panel. Anything unusual happened to the Mac in the near past, bump or excessive humidity exposure ?
해당 답변은 도움이 되었습니까?
점수 3
댓글 5개:
Reference the answer to this question Black shadows from the bottom of the screen
Here's a second question on the same subject Screen issues, Back light dims & goes out
@danj I had missed that one..it seems like a flood as with the old GPU issue on A1286, and just two years after release of brand new machines. Probably it's just the beginning. It should be like bread and butter for a lawyer with some good will. I hope it will serve well Apple's soldering and glueing craze.
Sadly it's a design issue with the newer interconnection cables between the system and lid (2016 and through 2018 models). I've now have seen 14 systems! All with either the stage lighting effect (backlight ribbon) of display wink out when the screen is tilted more than 45 degree's or (datas cable from T-CON board).
@danj I haven't been crossing any so far, but that's probably due to the fact that in Europe we have two years warranty by law and they're expiring right now. I'll brace for impact, it seems it's just a matter of time.
댓글 달기
New Program
13-inch MacBook Pro Display Backlight Service Program
https://www.apple.com/support/13-inch-ma...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Imam Hossain 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 3,827
