주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
after 70 cm drop all buttons dead except home
hello,
my iphone fell on the floor yesterday. now all buttons on top and right edge are dead, i.e. power/lock, mute, volume up/down. also the headphone jack doesn't respond anymore.
what may be the issue here? i'm desperate :(
thanks in advance!
mario
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Most likely the Flex Cable #5 came loose from the Logic Board. This is the Flex Ribbon for all the buttons you describe. Flex Cable #5 has to simply be pushed back down onto Logic Board connector.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
hey brad
thanks for your quick response. i was hoping and to be honest expecting to hear something like this. now the question remains which ifixit.com manual i can adhere to get the flexcable back on again. you must understand i never saw my phone from inside before.
regards
Any of the manuals for the 3g or 3gs will get you to Connector #5, it's at the top, just left of the SIM Bay. I would watch a few youtube videos on opening iPhone with Suction Cup method. You have to open iPhone very slowly and carefully or you will damage ribbons at Top of iPhone especially #3. Also you risk damaging LCD because it is sensitive to repairs when the iPhone is ON. If LCD Flex #1 becomes loose during opening or repair it might be best to push Flex #5 back correctly and then Power OFF iPhone before trying to reseat Flex #1. Or maybe at least wait a couple of minutes so iPhone goes into Sleep Mode before you try to reseat Flex #1. If it was me I would turn OFF iPhone. But maybe only Sleep Mode is necessary to protect the LCD, I do not know.
hey brad! what do you like more, chief or boss? at least you earn one of those titles :-)
i opened the iphone very gently and then already saw that flex cable #5 is off the logic board. it was sort of tricky to put it into place, cautious as i was (raw egg like!). but after that i immediately closed the phone again (not to break the lcd or anything else), and... heureka: the power button button made my phone go ON again! so every other button works, too.
oh, now i got it: master ;-)
thank you brad.
댓글 달기
귀하의 답변을 추가하세요
mario su 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 855
