주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
Activate issue with no network works
Hello!
I have iphone 7 (A1660) with (NO service) problem , I tryed use ipcc files but carrier still Not Available, so I update to IOS 12 and now I stuck with activate issue(there is still no service,Even with use different sim cared), it saying Unable to Activate An update is required to activate your iphone. image below
I Noted when I eject the tray of sim cared, my phone do’s not say (No SIM card inserted ).
pleas help me!
Thank you before!!
Ibrahim
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 13
댓글 1개
I have same problem too
댓글 달기
답변 8개
가장 유용한 답변
I solved that issues by changing BBPMU IC on iPhone 7 and restore via iTunes then my problem solved.This videos help me to find the solution.Hope this works.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
where is the video? I really need your help sir, I got this problem for a month now
where is the video
@aresmuzamel
@MAKE
Click on solution to get video
댓글 달기
This is a known issue with the iPhone 7 modem. Send in for repair with Apple: https://www.apple.com/support/iphone-7-n....
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Apple says the fix it for free until you send them the device. I had the same issue and Apple says that my iphone needs a new screen due to a very little scratch and they are charging me 316+tax for that, so they fix the activation issue. Bottom line, they fix everything with the phone or nothing, you have to pay for the cosmetic issue so they fix the activation issue for "free". Scam
댓글 달기
I had this issue with iPhone 7.
Did a chat with apple representative and they had me go to my iTunes and make sure I was updated first. Then turn phone off and connect to computer. Then open iTunes and let it install update.
It didn’t work.
She next had hold down the power and volume up button for about a minute or two until your phone shows that it is connected to iTunes, then the iTunes screen on my laptop was showing that it was extracting, then when it was done it started to update.
Phone turned off after installing and I was able to set my phone up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
some people with this case get their phone back with changing baseband power ic on the machine board. May be y’all wanna try it too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
ich habe problem men iphon gleich ist was maen bite
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
if the model is of those : A1660, 1680 , A1779 then there is no issue coz apple said it, you can read this link :https://support.apple.com/iphone-7-no-se...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Fixed by adding another device to my account(iphone 6) then i removed my iphone 7 from list of trusted phones. That allowed me to activate.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
could you explain it a little bit more?
댓글 달기
My iphone 7 unable to activate
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ibrahim Hassan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 58
전체 시간: 21,197
