주요 콘텐츠로 건너뛰기
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo 프로세서
104 질문 전체 보기
Bottom LCD faded after HD replacement
I just used the fantastic Hard Drive replacement guide to upgrade my drive to 1TB, and all works well...
However, now the lower half of my LCD is slightly faded.
If I put the computer to sleep and wake it again, the screen momentarily appears normal, before fading down below.
Other than replacing the LCD, it there a possibility of reopening the iMac and fixing what I unknowingly changed?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
This is the very question that brought me to iFixit in the first place and I still don't know the answer for sure. I tagged a whole bunch of questions "half screen problem" if you want to do a search. We may now have new people with better answers than I found. top half of screen is greyed out
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I have this same machine ( a EMC 2266) sitting on my work bench with a fading upper portion of the screen. I have no idea of how to fix it. Any ideas would help.
How about it Dan?
Can you post an image of the screen with your question? Or in your case, the answer;-) Some views of the connector and the cable would be great as well. What have you tried so far about the troubleshooting? do you have access to the number of the LCD (I suspect it to be a LM240WU2)
댓글 달기
In the 2266 the LCD screen has four power supply cables for the CCFLs. The connectors are keyed, so if inserted correctly (looks like they could be forced), the CCFLs will light. The half screen suggests that at least one of those power connectors was not connected or not connected correctly. CCFLs usually rely on DC current, so the connectors cannot be reversed and still work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Christopher Sage 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 890
