주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
820-3476 Water Damage Green to Orange Light | NO BOOT | NO FAN |
I have no boot, no fan, I do have lights but PP3V42_G3H all capacitors on that line ground on both sides. I’ve cleaned the whole board, and every capacitor I cleaned specifically on that line to no avail.
SMC works because I can reset it and the lights on the charger will change and all that, but it won’t boot.
There is no corrosion on anything related to the line, and the only thing that had to be removed was C5250 because it was the only Capacitor on the whole board which was corroded enough to cause concern.
I don't know where to look at all! I need someone who has handled this problem before, I’m always up for a challenge and don’t mind putting any amount of effort into this one since it’s a first for me. Good learning experience.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
To get a spontaneous reboot: Disconnect the battery and the mag-safe. Press and hold the power button for 15 seconds. Reconnect the battery and mag-safe. If the logic board is good you should get a reboot spontaneously.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
@mayer Tried that, it does not work. Will not boot. Won't even try, I get absolutely nothing. But my SMC still works which is SUPER surprising, and confusing.
I'm clueless, maybe @danj has an idea.
Time to pull out the schematics and board views, peering into a good microscope with your DVM in hand to do a deeper inspection ;-}
Debugging logic boards is an art onto its self! Liquid damaged or not. I would jump over to Louis Rossmann's YouTube channel and watch his process of isolating out the circuits and finding the failure.
Thanks guys!
댓글 달기
귀하의 답변을 추가하세요
Noah Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 350
