주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
What type of SSD and Wireless Card this model uses?
Hey, I have a dead MacBook Pro Late 2013 and I was thinking about removing the wireless card and the ssd to use it on another computer, but I didn’t find what connector they are, somebody can help me?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The SSD is a custom drive made for Apple and uses their own connector. You’ll need to give us an idea on what system you are thinking of installing it into. Or, you can get a USB case to house the drive so you can use it as a portable high density SSD drive. As an example OWC Envoy Pro
As far as the Airport board, there is really no way to re-use it outside of a Mac system or a system which uses the same WiFi/Bluetooth board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I would like something like a adapter for normal PCIE or even sata
The only thing you can use is a PCIe card for a PC that supports the Apple PCIe/AHCI 2.0 x2 SSD's like this one OWC - PCIe SSD Expansion Card
댓글 달기
To answer your question, the AirPort card and the SSD would be the two parts I have included below. Those parts will be compatible with the Mac you have chosen to be the device that you have a question on.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board
[연계 제품이 누락 또는 비활성화 됨: IF123-123]
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board 이미지
상품
$49.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I already have those, I want to know what connections they use, so I can get adapters to work on another computers, got it?
Aha, ok. @mayer Any ideas? Is it a form of SATA?
댓글 달기
귀하의 답변을 추가하세요
Heitor Scatolin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 58
