주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Problems After Screen Replacement
See video for details. It basically starts up with a bright white light and then turns into vertical lines. It also sometimes displays 5 lock screens vertically. I have already tried a soft reset, but it had no effect.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Do you still have the original screen in a somewhat working condition? If so, try the original screen and see if this problem persists. That way we can rule out the screen.
Update (10/07/2018)
@blewisgabriel Sounds like we have our problem solved! If you wish you can buy another replacement screen at the link below. Go ahead and mark this as correct for completion sake.
iPhone 4S Screen
iPhone 4S Screen 이미지
상품
iPhone 4S Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
I am working on that now...I will post an update.
@blewisgabriel Sounds like a plan! Keep us posted :-}
@ajcooke01 Well, I put the old screen back on and it works without a problem. I guess it is just a defective screen.
@ajcooke01 I tried putting the new screen back on and now the picture vibrates. Do you know anything about this?
@blewisgabriel You mean the phone won’t stop vibrating?
댓글 달기
If you still have the original LCD screen, put it back in and see if it does the same thing. It might be a defective / bad 3rd party screen you have there, or it has been damaged. A similar sort of white to gray vignette and vertical lines problem happened to my LG Optimus L90 - that is, after I put it through some physical stress tests.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Benjamin Gabriel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 73
