주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Where do speaker wires connect?
When I replaced LCD and glass I broke the blue wire to the speaker not sure where this wire should be connected, Audio is great to ear buds but need to get speaker working, need info on connection and how to get to the underside of board if wire is connected to that side of the board.
Thanks Dave AA6DB
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
David Bird, take a good look at the guides on here and that might just give you the answer you need iPod Touch 4th Generation good luck
댓글 달기
답변 1개
선택된 해법
Speaker leads wires can be connected as follows, looking at the itouch with top away from you you will see two solder tips one on the left connect red lead the blue goes to the next solder tip to the right of the red one. Not necessary to remove board.
Dave AA6DB
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
David Bird, great job. All you have lefty to do is to accept your own answer. That way everyone will know from now on how to do it. Great job...
댓글 달기
답변을 추가하세요
David Bird 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 4,505
