주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1921, A2101, A2102, A2104. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S Max"로 발음합니다.)
375 질문 전체 보기
repairing back glass iPhone xs max
Hwy, do you guys know how to fix the back glass of iPhone XS Max?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 13
댓글 1개
Hoy iphone está bloqueando el Face ID solo por cambiar la carcasa por que será??
댓글 달기
답변 11개
가장 유용한 답변
My understanding is that if you heat up the back with a heat gun or blow dryer you can peel the glass off as it’s held on with adhesive. If you broke the back glass you really have nothing to lose with getting it off, you can hack away at it until it’s off with an opening pick and/or a Jimmy. Just don’t use excessive force in a way that would damage other components of your phone. Make sure you have your replacement back glass on hand before doing this, though!
HOWEVER…
There is no such replacement back glass existing at the moment that would work for this phone that I am aware of at the time of this post. You may have better luck finding that part.
iFixit Opening Picks (Set of 6) 이미지
상품
Jimmy 이미지
상품
Jimmy
$7.95
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
This repair has been made intentionally difficult. You will either need to heat up the glue to soften it and hack away at the glass, or freeze the back and chip it off. This can damage your phone, so take everything out of the housing first. You will then need to clean the glue off the frame, and then re-glue it back on (the exact glue I am not sure of). However! The glass to replace it with does not exist yet, and when it does, it will either be blank or be breaching copyright laws (as it has the apple logo on it). It cannot be done at this stage, and (I can’t believe I am suggesting this) either live with the cracks, use a skin or a case to protect it or if you really want it fixed, give it to apple.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I have just done a back glass replacement. No big issues, have to have a focused heat gun to heat the adhesive. Several videos of this being done on youtube. Ordered rear glass from DHgate
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Can you provide a link to the seller? Thanks.
Can you tell us which back cover you got from DHgate? There are a number of them and it is hard to assess which ones are appropriate for an iPhone xs white
댓글 달기
I have some small cracks in the rear glass on one corner. I don’t remember dropping it, but the cracks start at one corner, so it must have gotten dropped at some time or another. The phone works fine, so my comment is why bother to fix it at all? Who cares? It certainly isn’t worth $599.00 to get it fixed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Replacing the whole housing is the easiest option, but if you want to replace the glass, heating the back is possible, and some people say cooling the phone with liquid nitrogen is easier, although both are intentionally extremely hard.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The issue that comes with replacing the back panel, is that it’s glued onto the internal housing. The actual internals are apart of the back panel, and not the front.
Apple is currently 'repairing’ devices with cracked/shattered/damaged back glass panels by replacing the entire internals.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Just replaced the whole housing it’s much easier and purchase the “naked frame” because only OEM cables seem to work properly with this phone
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Laser machine. This machine can efficient separating iPhone xs max back glass. Search video guide from YouTube. And I know REWA have pulished a nice tutorial on their official channel.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I get adhesive off the back of the phone without a adhesive gun or a Heese of plate
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I get the Hee-seop off the back of my iPhone without using a Heese of girl or a hair dryer
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You really can’t you damage your phone trying to pry it off you can buy a small heat gun from home Depot for about 30 bucks better then paying 300+ for someone to replace it for you
댓글 달기
귀하의 답변을 추가하세요
Ahad shabbir 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 24
전체 시간: 76,090
