이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
I have had some really messed up computers over the years and so I maybe able to find a solution but I need more information. Is there any sign of life whatsoever when you turn it on like anything on the screen, any beeps or is it not responding or turning on at all?
A possible reason towards why your computer will not turn on is a bad charging cable. Attempt using a different cable and see if the computer will turn on. If not then it will an internal malfunction.
2Sarcastic4U 의
