주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
배선(wire)은 보통 원통형의 유연한 금속 가닥 또는 막대입니다.
iec c14 plug - Needs replacing
Hi all
I need to replace the “iec c14 plug“ of my peavey speakers:
이미지
이미지
I have bought a new iec c14 plug but since I have not replaced this before so I was wondering if you give me some advice.
  1. How do I detach it. Will is pop open if I pull?
  2. How so I install the new one. Solder and tape?
If there are any instructional videos that would be great.
Many thanks
Usama Ahmed
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You’re replacing the IEC C14 appliance inlet (the male chassis connector on the speaker). Good news: it does NOT pop open from the outside, and you should not just pull it out.
Since this is a mains voltage (230V) part, safety is critical.
⚠️ Before You Start
  • 🔌 Unplug the speaker from the wall
  • ⏳ Let it sit for 10–15 minutes (internal capacitors can hold charge)
  • If you’re unsure at any point → better let a technician do it
How to Remove the IEC C14 Inlet
These connectors are usually mounted in one of two ways:
1️⃣ Snap-in type (most common in speakers)
  • Held in place by plastic retaining clips
  • Removed from inside the cabinet, not from outside
2️⃣ Screw-mounted type
  • Held by visible screws (yours does not appear to be this type)
From your photo, it looks like a snap-in panel mount IEC C14.
✅ Correct removal method:
  1. Remove the rear amplifier plate from the speaker (usually several screws around the edge).
  2. Carefully pull the plate out.
  3. From the inside, locate the IEC connector.
  4. You will see two plastic retaining tabs (one on each side).
  5. Use a flat screwdriver to press the tabs inward while pushing the connector out.
👉 Do NOT try to pry it out from the outside — you’ll damage the housing.
How It Is Wired
Inside you’ll see three terminals:
L  = Live (brown wire)
N  = Neutral (blue wire)
⏚  = Earth (green/yellow wire)
Often marked:
  • L
  • N
  • ⏚ (earth symbol)
Take a clear photo before disconnecting anything.
How to Install the New One
🔧 Connection Type
Most IEC C14 inlets use:
  • 6.3mm spade (Faston) connectors
  • NOT solder directly
👉 You should NOT:
  • Twist wires together
  • Use tape
  • Leave exposed solder joints
✅ Proper method:
  • Use crimped insulated spade connectors
  • Or reuse the existing ones if they are in good condition
If your new inlet has solder tabs:
  • Solder properly
  • Use heat-shrink tubing
  • No electrical tape as primary insulation
Important Safety Checks
Before reassembly:
  • Make sure earth is firmly connected
  • No loose strands
  • No wires touching metal parts
  • Connector fully clicks into place
Very Important ⚠️
If this speaker is a Peavey active (powered) speaker, it contains:
  • Mains voltage
  • Large capacitors
  • Potential shock hazard
If you’re not comfortable working with 230V wiring, this is a quick job for a repair shop.
Video Resources
Search YouTube for:
  • “Replace IEC C14 panel mount connector”
  • “IEC C14 snap in removal”
  • “IEC inlet replacement amplifier”
Channels like:
  • Afrotechmods
  • EEVblog
  • ElectroBOOM (educational, but less tutorial)
Quick Checklist
✔ Remove amp plate
✔ Press internal retaining tabs
✔ Photograph wiring
✔ Reconnect L / N / Earth correctly
✔ Use proper crimp or solder + heat shrink
✔ Ensure tight snap fit
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Usama 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 41
전체 시간: 492
