주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
444 질문 전체 보기
MacBook Pro - How to use external monitor right from boot/login screen
My macbook's display is not working, and it just shows some lines for most part of it. But I can see(barely) it is booting and waiting at login. I want to connect it to external display and take a backup. The problem is that the external display becomes secondary display and I do not see the login prompt on it to work.
Is there a way to make the external display the primary display or to mirror display using some keyboard shortcuts, as I cannot see whats on the screen at all?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
If you have access to a USB or Bluetooth keyboard & mouse. Restart your system and then close the lid so the lid sensor acknowledges the lid is closed your external display should automatically become the primary display.
If this fails you may have something deeper here than just a messed up LCD.
해당 답변은 도움이 되었습니까?
점수 13
4 Comments:
Brilliant! Worked for me.
You need the magsafe in and power on too. It doesn't work from battery.
Worked for me
worked for me too :)
댓글 달기
Here’s a guide on how to do so. Pretty cool guide in my opinion!
http://osxdaily.com/2010/12/21/broken-ma...
해당 답변은 도움이 되었습니까?
점수 1
2 Comments:
@ajcooke01 - Be careful! This guide was for the older A1211/A1212 MacBook Pro. The newer MacBook Pro retina series are a bit different. I wouldn't disconnect the display lid as you would loose Bluetooth & WiFi
@danj I didn't say to disconnect the lid, it was just in the very unlikely case the OP would actually do something like that.
댓글 달기
I'm trying to connect Mac book pro 2019 from usb c to HDMI cable to Samsung TV before login. But it's not detecting in TV even after connecting charger and closing lid. Any idea why?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Try a different port, adapter and/or cable as one is not working properly.
댓글 달기
So i have a macbook with usb-c/touchbar with a broken display and other boot problems.
The screen doesn't do anything and the touchbar sometimes shows something, the capslock light is working but no external screen, even with the lid closed/charger connected/external keyboard amd mouse. Any idea where to start?
Ps. I got internet recovery to work on the external screen but it was in extended desktop mode so i could really see anything....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Harish 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 33
7일 전: 334
30일 전: 1,500
전체 시간: 70,005
