주요 콘텐츠로 건너뛰기
The Samsung Series 7XE700T1A was made in China in 2011 and includes 64 GB
6 질문 전체 보기
Wide black line down center of screen
Would this wide black line mean I would have to replace digitizer and glass or just one of them? The touch screen still works.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
A black line down the screen would likely indicate the LCD is broken, so you’d have to replace the LCD display itself. If glass is broken, you’ll want to replace that; if not, then don’t. If touch is still working, then the digitizer is not broken. I’m not familiar with that model, but depending on the tablet some devices have the entire LCD + digitizer + glass as one assembly, whereas some have the digitizer + glass separate from the LCD. If that tablet has a single display assembly, you’d need to replace the entire thing; if it has a separated assembly you could possibly get away with replacing just the LCD (assuming the glass isn’t broken).
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Wonderful! You have answered my question. They are 2 separate pieces.
댓글 달기
you cracked the screen in that spot can’t fix that you can still see out of it right?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Laura Bellah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 193
