주요 콘텐츠로 건너뛰기
The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
33 질문 전체 보기
Blinking caps lock solid red wifi light.
It blinks every 4 seconds or so. Solid red WIFI light. No beeps. If I leave it on for a while or really any time it gets hot it boots like normal and has no problems until it cools down. Why is this happening? Is it time for a new laptop? Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
- Start by doing a hard reboot, remove the battery and unplug the AC adapter then press and hold the power button for 20 seconds then try booting it up again.
- If this will not work, do test the AC adapter if it's working properly. Remove the battery and power the laptop with just the AC adapter connected and see if it will boot up or not. do also try a different AC adapter that has the same voltage and see if it will work or not.
- Proceed with reseating the RAM's if trying a different AC adapter will not work, remove them all for couple of seconds then put them back in making sure everything is seated properly.
- If it will still not work, connect an external monitor and see if you'll get any display from it. If there's a display on the external monitor that could mean that the problem is the built in display.
- But if there's still no display on the external monitor that means the problem lies in the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ive already tried that. Im just trying to figure out why it only boots when its hot
댓글 달기
귀하의 답변을 추가하세요
Ethan Leroux 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 2,803
