주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
MacBook water damage - fixed, but keyboard still not working
So long story short, I spilled a small amount of tea on my MacBook Air.
I followed everything in the guides and videos I found online - removed battery, put the Mac upside down and let dry, took it all apart and cleaned each component carefully with isopropyl alcohol, let everything dry and put back together - and now everything works properly EXCEPT the keyboard. I plugged in a usb keyboard to test it, and that worked fine.
The only thing I didn’t do in my repair attempt was actually remove the keyboard itself. I got as far as taking the backlight panel off, and I even removed the like 50 screws of the keyboard, but I couldn’t seem to get it out without damaging it so I left it.
Does anybody have any tips on what I should do? Is it safe to remove everything again leaving just the keyboard itself attached to the frame, then soaking it in an isopropyl alcohol bath? Not letting it touch the screen of course.
Thanks for any help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
unfortunately the only way to remove the keyboard on your model of MacBook Air is to tear it off from the top case as there are rivets that hold the keyboard in place. A complete top case replacement ( MacBook Air 13" (Mid 2012) Upper Case with Keyboard ) would be a much easier replacement, but also more expensive.
At this point I would either replace the keyboard or the topcase. An isopropyl bath wouldn’t likely yield in a positive result. If you decide to replace the keyboard I would plug it in before installing it to test that it will fix your issue, and also make sure you remove the keyboard slowly with a lot of tension to ensure you remove 99% of the rivets. You will also need to replace the rivets with screws so make sure you get a pack of keyboard screws as well.
Best of luck and happy screwing!
MacBook Air 13" (Mid 2012) Upper Case with Keyboard 이미지
상품
$149.99
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
Thank you this helped for me too.
댓글 달기
귀하의 답변을 추가하세요
Brad Barnes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 303
