주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
A few days back my MBA 2015stopped working. What could be the problem?
A few days back it simply stopped working. I put it on sleep and it never got on. Although, it could run the external mechanical hard drive up until 2 days after this. Following this, it stopped working. Tried SMC, NVRAM reset and everything. The fan won’t turn on too. There’s no chime. The Magsafe led would turn green when plugged into my Macbook. Any help would be appreciated. I do not remember spilling a drink on it, although I live in a pretty humid area.
Update:
When I do SMC, the light on my charger pin changes from orange to green but still the mac won’t turn on.
Update 2:
I have attached the battery’s screenshot. The LCI on the logic board is not triggered.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Disconnect the mag-safe adapter. Disconnect the battery from the logic board. Press and hold the power on button for 10 seconds. hook the battery and mag-safe back up. You should get a spontaneous reboot.
MacBook Air 13" Early 2015 배터리 교체
Next download, install and run Coconut battery and post your results
How to Test a Mac Laptop Battery
MacBook Air 13" Early 2015 배터리 이미지
안내서
난이도:
운영
15 minutes
Mac Laptop 이미지
안내서
난이도:
아주 쉬움
3 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Nothing happened. During SMC, the light is changing.
I have a MBA 2017 model, should I try its battery in the faulty one to check if the battery is at fault?
It's compatible, give it a try. But, I'd do it the other way around so you can test the battery in the new machine.
Thanks @mayer, I did the same. I have updated the battery's screenshot in my question. It still won't power up. No activity on the fan. I don't know what the problem is.
댓글 달기
귀하의 답변을 추가하세요
Gaurav Mishra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 164
