주요 콘텐츠로 건너뛰기
2017년 3 월에 출시된 G6은 Android 7.0 기반 LG의 주력 핸드폰입니다. 이 기기는 모든 주요 무선 통신사에서 사용할 수 있습니다. 이 기기를 물리적으로 수리하면 방수 기능이 사라져 물에 취약할 수 있습니다.
20 질문 전체 보기
Touch screen not working
I have a phone labeled “LG Fortune 2”, I chose “G6” because appearance-wise it was the closest, “Fortune 2” not being in the list of devices.
It got wet though not soaked - rained on , predictably would not boot. The moisture telltales all turned orange.
I dried it out and it booted fine, screen lights normally, but the touch screen will not work at all. The only way to get it to light is the home button.
What, if anything, can be done to correct this?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks. I will replace the digitizer. I see they can be had for about $10.
댓글 달기
답변 2개
선택된 해법
Sounds like you need a front digitizer replacement. If that isn’t the issue, it could potentially be a logic board short. Water damage is tricky to diagnose directly, but I would try a digitizer replacement first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
As Jonathan said, water damage is tricky to diagnose. There may be corrosion on the screen connector causing the touch not to work. Its also possible a component on the board is shorted out. You will have to replace the whole screen assembly (glass, digitizer, LCD) if you want a new touchscreen because it is bonded together. A new screen will do nothing though if the corrosion isnt cleaned off of the connector, or if the logic board is shorted. Its going to be about the same or cheaper to replace that phone than fix the screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 1,763
