주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Screen fault // logical board - working when closed
Hi
Firstly thanks for taking the time to read this. My A1502 13” was working fine, until I shut the lid followed by a unfortunate drop, no more than 5/6 inches onto a rug. I thought nothing of it due to the lack of height and visually didn’t seem too destructive.
I was then greeted by a black screen upon reopening a few hours later.
Now, in terms of troubleshooting, I have done all the required resets, as well as opening the back up, taking everything out and rebuilding. I did not remove the trackpad or batteries.
I can get the laptop to work with no issues when using and external monitor via HDMI. I I also have to have an external keyboard/mouse connected and have the lid closed (I have to quickly shut the lid upon powering on). If I try to open the lid once logged in it will cease to work correctly, and freezes. Another observation, on initial power I have no keyboard backlight, but do have a green-light on the caps lock.
Now my question is to what the issue is and what component/s may I need to replace to get this rectified.
Thanks,
Ollie
Edited for grammar!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@danj and @mayer are the experts on these types of problems.
Thanks! Hopefully will hear from them.
댓글 달기
답변 1개
선택된 답변
These retina screens are very fragile with just about 1mm thickness and it takes very little to break them..a few inches distance bump was probably enough to create an internal short on top of breaking it. When you close the lid, power to the screen gets cut off and Mac can work. If you can live using it with external monitor you can try unplugging screen from the logic board, but if you want to use it as laptop there’s no other solution but replacing the assembly, replacing screen only is very difficult and might be unsuccessful in the end.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Ollie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 86
