주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
Switch on my tablet needs replacing
My on switch on my note pro is faulty . How can i replace it without loosing my photos and data downloads ?
the tablet is going perfect,but the switch seems to be broken or just worn ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Joe,
I would advise that you backup your device before making any repair effort.
  1. From a Home screen, navigate: Apps icon  > Settings > Back up and reset.
  2. Tap Back up my data to enable or disable.
 Enabled when a check mark is present.
 If disabled, existing backups are deleted from Google's servers.
  1. From the Backup account field, ensure the appropriate account is listed.
 Back up my data must be enabled.
  1. To change accounts, tap Backup account.
    1. Tap the preferred account
  2. Tap Automatic restore to enable or disable.
This will ensure you don’t lose any data.
As far as replacing the switch, this is the part you will need:
[링크된 제품이 누락 또는 비활성화 됨: IF331-000]
The volume button board contains the board for the power button as well. You won’t nee to replace the physical button you see on the outside, the problem would be in the circuitry beneath.
HOWEVER, you did not include your device model information. Please ensure this part is compatible with your device.
Thanks
Ryker
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
JOSEPH H CRAIG 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 249
