주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
My ipad pro doesnt charge
the device doesnt charge when plugged in. The charger is confirmed to work, and i have already replaced the battery. Im thinking that the large ribbon cable that lays flat at the bottom of the device is damaged. But i am not sure, any ideas would be much appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Your Tristar IC is likely damaged or broken. That requires either a logic board replacement or a microsoldering job done. I would talk with your local microsolderer about this, replacing the Tristar IC is a lot less then replacing the entire logic board.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I cant seem to find a tristar ic for this ipad model would you be able to help track one down? Also the model id is a1652.
Also can i change the logic board and just use password to unlock the device without using touch id
I couldn’t find a Tristar for your model iPad either. Indeed you can do that. It’s not the least expensive option though.
댓글 달기
답변을 추가하세요
Michael Johanson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 18
전체 시간: 179
