주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Overheating After Screen and Battery Replacement
I replaced the battery and screen on an iPhone 6 (with iFixit parts only). Now when I start up the phone, everything appears to work but the phone gets hot - real hot.
I opened the phone back up and found that it is this part which is overheating:
I don’t believe any other component has heat coming from it.
I would appreciate any help I can get. All this into the phone and now it has an overheating problem!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 3개
선택된 답변
That EMI shield covers CPU and in the upper left corner backlight driver and support components. Since you replaced the display would be reasonable to think that when it got broken backlight circuit was damaged too and one or more partly shorted components are causing overheating. Unfortunately it is very likely pretty soon backlight will eventually fail if the shorted components don’t get replaced.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Seems like u blown the backlight filter dont ever disconect lcd without disconect battery 1st always remember
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Is the phone just junk then??
No - it is not "Junk" but it can be better than it currently is
댓글 달기
Hello!
I looked and looked for images with this part in particular
Short version, my mom was at work and all of the sudden her iPhone 6 got very hot and didn't turn on or charged(this is in September 2020)
Today I changed the battery and the screen with out a problem, but as soon I tried to turn the phone on I realised that it didn't and the same part as the one above was very hot, I think it is the processor right?
It receives power, but it overheats after 10/15 seconds and again that part is very hot.
Can someone help me please?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Exact same thing happened here! It got really hot over night and wouldn't charge or turn on. I am trying to replace the battery but every time I plug in the battery it gets really hot especially when I try to charge it. Can someone please try to help me? Thanks!
sorry for my english, i had a battery replacement in my iphone 6 yesterday and i notice that my phone is really hot particularly in the bottom part of the back camera, it's so hot I don't know what's the problem can someone answer this? thankyou so much im really hoping for an answer thankyouu😭😭❤️❤️❤️
댓글 달기
귀하의 답변을 추가하세요
WWonewocGuy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 99
전체 시간: 16,757
