주요 콘텐츠로 건너뛰기
The Capresso Infinity Model #565 is a conical burr grinder that is used to grind coffee beans varying across sixteen settings from Turkish fine to coarse.
14 질문 전체 보기
Why isn’t my coffee grinding?
I plugged the machine in, and put my coffee beans in the top container, but for some reason it’s not working. My dial is turning and I have the black dot on the top container lined up with the coarseness I want. What else should I do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
student question
댓글 달기
답변 1개
선택된 답변
Hi! So there might be multiple reasons that this is happening.
Check for the following:
Your top conical burr has been placed in the device correctly. You should have it flat side down.
There is no compacted coffee grounds in the grinding chamber. Sometimes excess grinds can get stuck in the conical burrs or in the crevices of the grinding chamber. If you find this to be the problem, gently clean it out with a brush or paper towel.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have the same problem. It worked fine before I removed the top burr and cleaned it. I replaced it correctly but now the grinder doesn;t grind,. The grounds container is correctly placed, burrs correctly placed, no grinding happening, Do I need to replace the motor? Got any trouble shooting advice?
댓글 달기
귀하의 답변을 추가하세요
Elizabeth Roach 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 58
전체 시간: 817
