주요 콘텐츠로 건너뛰기
Repair guides and support for the Motorola Moto G6 Play, Released May 2018. Model number XT1922.
Moto G6 Play replacement screen 1mm too short
I know this is going to sound weird but I ordered a screen from 2 different suppliers for a Moto G6 Play and both replacement screens are 1mm too short. Everything lines up at the top and the shape is perfect but there is a gap at the bottom. The flex cables work and are a perfect match to the original. Anybody else have this issue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 3개
Yes got the same problem, I recommend buying with frame assembly
Our shops have ran into this issue as well. We now buy it with the frame only.
Unable to find XT1922-9 replacement lcd w/ frame...
댓글 달기
답변 2개
선택된 해법
Hey Jestin, I have since discovered there are 7 variations of the G6 Play. Some of them use a 150mm screen and some use a 152mm screen.
If the supplier doesn't specify, you will most likely get a 150mm.
I found an eBay seller that lets you pick which one you want and it worked great.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I had the same issue today with the screen i received from a local supplier today. Everything works on it, its just short.
I end up replacing the screen anyway.
댓글 달기
iFixit sells genuine Motrola parts. I would sugget you search on iFixit for availability of the specific moto part you need in order to ensure a proper fit. The genuine parts are going to be a lot more reliable!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
brentongraber 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 2,327
