주요 콘텐츠로 건너뛰기
An Android 4.4.2 smartphone released November 1, 2014.
Why cant I touch the screen on the phone
I think my mother board is gone out how do i fix it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@khunt2002 Is the touch screen unresponsive?
댓글 달기
답변 1개
if your touch screen is unresponsive, there are a few things that could be going wrong.
1) most commonly, your digitizer is failing. The digitizer is the touch processing panel under your glass. you can try to get a new one and see if this fixes your issue.
2) this is less common, but will cost less to fix, which would be a software bug. run a factory reset through your recovery mode on you device to see if it fixes your touch.,
3) board level failure. the least common to cause a straight lack of touch, but the board may be having issues. without excessive training in Microsoldering, as well as access to the schematics for your device, you will be unable to repair this, and will have to replace the motherboard with one from another device instead.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kyra Hunt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 140
전체 시간: 365
