주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Earpice stops and sounds wierd
Okey so i have my screen replaced, after a while my earpiece starts to sound wierd, like static sounds when its playing music. After a while it stopeed working. I got it replaced, This has happend for the 3d time, im beginning to suspect there is something that makes the earpieceo bad and then stop working. Pls help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It sounds like it either isn’t being positioned properly, or the person who replaced it may have damaged the connector on the logic board. My suggestion would be to clean the connector very carefully with atleast 95% isopropyl alcohol, to prevent liquid damage. Making sure it is secured properly under the housing bracket, and on the logic board connector is crucial as well. If you do not feel comfortable doing this yourself, you should either seek out another person to repair it, or take it back to the same person at last resort and explain the issue. Good Luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes, im gonna take it to a repair shop, they have had it replaced the second time and now when i will replace it the third time i will tell them whats going on. Because it works fine for like 2 weeks, then it strts to go bad.
댓글 달기
귀하의 답변을 추가하세요
Agge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 36
